2006 Chrysler 300c
Guest Zrok
These cars have an additional 'starter/accessory' wire... although in most of the wiring info that's available, it lists 2 resistance values w/ relays to accomodate this type of arrangement. HOWEVER... no one really has info for the 2006.. it's only available for the 2005 model yr. the '06 is different. the values are different than the '05 AND they MUST be wired as additional ignitions BOTH relays. Hope this helps anyone that's encountered one of thest bastards... took me a whole day to do one. :( (still has resistor locks) and they want you to isolate the parking lights through a resistor but couldn't gte that to work, tried it with the measured resistance at the switch and kept getting 'service park assist system' on the display... had to get a + park light wire in the pass. kick that worked.
Hope this helps anyone that needs it. :broken
    2. 6
    4. 6
    5. 4
    6. 5
    7. 6
    8. 0
    9. 0
    10. 5
