Mercedes CL 55 AMG Help
Guest chip01
The car is going ok did the front windows really easy by tucking the bottom of the tint in first just under the seal with no problems but the rear quaters are a bit tricky I have sorted out the issus of the windows moving my tricking the doors with switch but are struggling with the best way to make a pattern and best way to install them . The gasket above runs from the rear to the front of the car and looks pritty difficult to remove is there anyway round this
Thanks in advance
Chip
Guest Beeline
Thanks in advance
Chip
[*]370188
this car will be very hard with little experience.....
Guest naughtydog
Search for posts from theartoftint - there is a trick to those quarters, you can use a b it of yellow turbo to hold the window out a little while you slide.
Naughty
      Help Needed! - Graphtec FC4100-75 - Software/Compatibility/Drivers/Communication/Blades/Setup
      Need some help
      Wtb Solar Gard Supreme NR 40
      Canadian Tinter Looking for work in US
    6. 3
    7. 3
    8. 4
      At What VLT% does visibility start being impacted
    9. 0
      WE ARE HIRING - Window Tinter needed Waldorf MD 20602
    10. 6
