having a problem
Guest Djkyle65
Guest Djkyle65
So im tinting my windows today and I run into a problem seems like on my roll ups 0n my 1998 silverado that when I lay the tint on the window and start getting the water out I end up with a few lines that look like creases in the tint any ideas? I also seem to have some bubbles I cant get out shrink ?
Guest darkdan
Then it's a crease.
Be gentle on it and don't crease it.
Up your slip solution a bit too.
The little bubbles you can't shrink....dirt.
Try again.
if you dont take off the panel, when tinting you do the top half of the window, after doing what you gotta do, you roll it upt and take off the remainng liner left to take off, that could case the film to leave a mark where you took the remaining of the liner :beer
I've lost myself in this one trying to explain
