05' malibu hints
Guest dumplin
Guest dumplin
I did an 05' Malibu Friday , door panels are cake to r&r . Front panels have two push pins on outer edge , plastic cover behind door pull with two torx screws , speaker panel pops out and slides up , door latch is a little tight , small ,flat screwdriver makes short work of it , rubber seals slide right out . Rear door same as front only minus speaker panel . Rear glass goes in easy one piece and lays smooth over dot matrix border , no matrix at the top . hooray !
Guest MidcoastMW
Man those roll up's suck!!! 2 times I cut the film a little too much oversize and couldnt get it behind the rubber trim(on sides and top corner) without focking up the rest of the film. :popcorn
How are yall handling these rollup's?
Guest haroldshouseoftint
yank the bottom rubbers out, and its a cake walk no problem sliding the tint in.
I overcut everything (almost) and have no problems with em :popcorn
Guest MidcoastMW
really?? damn I pulled the whole panel and the felt gasket. I even shot the sides with my extra strong slip solution... :spit maybe its a rookie thing? :beer
Are you using a 2-ply film?
