d60 mystery
My d60 leaves an unconnected cut in each and every job. Before weeding I have to find it and manually finish the cut or else the weed will be screwed up. I don't believe its in the software because I can unplug my computer and just run a test cut and it still does it. Can't get a straight answer from summa. Maybe someone else has had this problem? Thought it might be the head but hate to invest in that without knowing for sure. Thanks
Guest darkdan
Adjust blade offset.
Also, you might want to try different cutting software. A few out there (flexi 8 and up, signblazer, etc) have an "overcut" feature that continues the cut past the starting point. This way there is no little notch left over.
