Double Cutters
Guest CloudWalker
Guest Zrok
if you shrink with the liner facing in, there's a HIGH possibility of scratching the film side ..not good, I use a really smooth hard card and don't worry, some of you that haven't tried it might wanna use a paper towel aroung the hard card. the liner n the outside is just so you don't scratch the film.
Guest SQUEEGEE
Liner side out to reduce incidents of scratching like ZROK said and because the liner side out will allow you to apply more heat which is necessary to shrink two pieces of film at the same time.
Guest psychotinter
holy sh*t is realy does work. I tried it on my 2000 Cobra & I think with a little more practice well we will see I had 2 creases in the center. :cool
Guest TintEater
I double shrank Llumar ATR and found that it worked well on windows that aren't super-curved. But, when I tried it on 3M it wanted to crease. Depends on the film I guess.
