`01 CLK Merc. need help
Guest luckistryke
Guest Litespeeds
The 01's are not that hard. The only problem that you will run into is the rear window if you need to tint behind the 3rd brake light. I am not sure how to remove the rear deck so I tell my customer's that I need to cut around the 3rd brake light. The last one I did, I managed to get the tint behind the 3rd light with the new tools that are out on the market. The rear quarters are very easy. The front doors are easy once the panel is removed.
The newer CLK's are a little trickier because the rear quarters roll up and down. I figured out how to tint those so now it isn't that hard anymore. The rear window is a piece of cake but the front doors are similar to the 01's. Good luck.
    2. 4
    3. 4
    4. 3
    5. 4
    6. 4
    7. 1
    8. 3
    9. 1
