09 A4 3rd Break light
tintmor
maybe you plugged it back in with the engine running...it will see no brake light and then start to see it again and report a problem.
After unplugging the light, do not cycle the key, this will cause the ECU to look at all parameters and see a fault in that circuit.
Unplug the light, tint the window and plug it back in BEFORE you cycle the ignition key...
That should prevent it from happening... :beer
Same thing happens when you unplug an airbag to remove a seat, if you cycle the key when it is unplugged, it will turn on the airbag light...
    3. 8
    4. 8
    5. 2
    6. 8
    7. 8
    8. 8
    9. 2
    10. 8
