2002 Range Rover
Guest shadowline
Guest shadowline
Got a 2002 Range Rover boked in. Not had one of these in before had the model before, pulled the rear door panals, on those (no problems) and removed the upper internal rubber seal/gasket on the top of the doors. Where are the fixings for the rear door card on the 2002 model (havent looked at one close up), and does the upper internal seal pull off like the earlier one? Or can the film be slide in? Thanks Guys
which Range Rover is it.
Guest shadowline
2002 Range Rover Vogue the "newer" shape one
seals stay on ,panals pull at top just take one screw out at door open lever an pop panal at top all rest no problem easy enough car.
Guest shadowline
Cheers Guys, I know the panel pulls quickly on the 97 style models, but I havent seen the newer shape one close up. Hopefully then they should be ok, at least the quarterlights are easier than the bloody old model!!
