F-250
Guest aschesh
  • Replies 26
Guest cme4tint
When matching factory tint, ask the installer to put samples of his film on your front door windows prior to the install so you can see how good it will match. Not all films look the same and don't have the same appearance.
some guys here take the window out.
myself I trim the gasket out on the inside that gives you room to slide the tint in with no light gaps. I stick my olfa blade out a click or two and just trim around the gasket on the inside. I trim the pattern on the outside and stick it in.
Guest suntekcar
MDOG thanks for the nice drawing, I don't care what they say. So, when you trim the pattern on the outside a little larger, are you cutting the film out on the rubber gasket instead of on the glass as if you normally would if you had the black boarder?
    2. 2
    3. 2
    4. 2
    5. 4
    6. 0
    7. 6
    8. 4
    9. 0
    10. 4
