2011 Camry
Booms
The 3rd brake light is made into the rear deck. if you don't have a titan, bulldozer, etc., you can pull both side panels then pull straight up on the rear deck and pull it back 4-5 inches and have tons of room. You can pull it back more, but make sure you unplug the wire to the light. :lol
Guest Mo Evo
There's plenty of room behind the 3rd light. I use a bulldozer with no problems. Though you need to use at least 00 steel wool (don't worry, it won't scratch) with a good alcohol based glass cleaner along with your mounting solution to scrub scrub scrub the outside quarters of the rear glass or else those defroster lines will go crazy with peanuts, stars whatever you want to call them. Alcohol because typical Toyota/Lexus 'rain-x' like glass...the water will bead.
It has been an issue according to him since 2010 models. Its not weld slag its from the defroster application. They believe its a post glass productioin prep at one of the plants. They steal wool them at the assymbly plant before they tint.
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
