Might as well put this cutter to good use
Guest mikeMN
A few things I do when doing a job such as the one you have posted.
After the premask is on,I will make a few lines under the letters all the way across with a straight edge and pencil to use as guide line to see,so it will be easier on site to level.plus I will make one vertical line directly down the center.to use as a on center reference mark.
I will also write the exact width and height of the graphic on the premask as well.
when doing any door,when I am locating the final placement of the graphic I will do this with the door in the closed position.
as far as price that would be determined by the market you are working in.and you will need to establish a minimum charge as well.like say they may just need a address cut and installed with just 4 numbers installed.and most commercial locations require a specified height and or size.
Guest scottydosnntkno
inkscape is good, but I use SignBlazerElements. It can do just about anything you need, and is very intuitive. Its just like a CAD software, so its second nature to me :drevil
    2. 1
      The direction of shrink
    7. 0
    8. 2
    9. 2
