98 Civic sedan quarter tips
Guest piter8841
Guest piter8841
Hi
I'm from Poland so forgive the grammatical errors: D
I have a problem with the quarter windows in my 1998 Honda Civic sedan.
How perfect to make these windows from the outside it looked nice.
The inner gasket is very hard and I can not push the film under it.
I would add that the problem is only with the gasket between the side window and quarter window.
This gasket is the same size on the outside and inside.
Surely you are among the professionals who know the solution to the problem:)
Pictures would be very helped me.
Greetings from Poland and I waiting for tips from you. :rollin
i'm not a big fan of trimming anything on someone's car. i do from time to time but only if i can make it look like nothing had been done. on the window you are reffering to i would say if your custmoer is not happy with you tucking the film in. then i would just remove the window to tint it. It's really not that hard to do, and will turn out alot cleaner that way.
trim the side and lower rubber a lil bit. place your film on the outside and cut the bottom and left vertical side. then cut the black bordered side last. do not cut then shift in any direction like most quarter/wing/vent windows. make sure the lower left corner is rounded because the rubber is rounded. it doesnt really make sense to not shift the film b4 cutting but it always fits perfect this way.
Guest piter8841
If I remove the glass if it is impossible to seal it off?
Does anyone have any photos of how the rubber cut from the inside?
How much do I cut the rubber on the inside and how to make it look straight and nice?
Guest filmslayer
:lol and as far as your grammatical errors....well, you did 100 times better than most guys around here. :lol
why don't you just say my freaking name??? :lol2:lol2
or mine :beer
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
