Dry Shrinking Questions
I have a couple questions pertaining to dry shrinking BG's that have been presenting an issue for me. I have been getting better at BG's in general but I find that either with the soap method, the tint will not want to glide for me and I usually end up with a crease somewhere if not more and then with the powder method, I go to wet-check it and I'll have very very very tiny creases in spots that I cannot smooth away on the ext. When I apply and squeegee, some disappear and some do not.
Just wondering if anyone has some insight as to what could be the cause of these issues?
And no, no pics since my screen on my camera is all f&%#ed up.
what soap are you using? ( use a bar of ivory) . Are you letting the soap dry enough B4 attempting ? If done properly, no wet check stage is needed with soap method. :thumb
from what ive gathered. soap/dryer sheet will give you some stick to the glass, especially when smoothing with a hard card. which is great because then you know that part of the tint is shrunk properly.
with powder, if you use too much the film wont stick at all and it becomes more of a guessing game if its shrunk, then a wet check, more shrinking............. but its awesome for letting the film float
1 tip with the bar soap. give it a few minutes then run some heat over it to double check its dry and to dry spots that may have been left with a little extra water before you put the film on for the shrink
Guest 515tinter
ya sounds like ur not letting the soap dry completely. i usually apply the soap to the BG then while its drying i will clean the inside of the glass and if i have to, remove the rear deck. by the time im done its completely dry and ready for the film
With the soap method, I let it dry usually for about 10 minutes or so, but maybe I am applying too much? With the powder, I used to use a lot and now use much much less so it seems to help but when I am wet checking it, I usually have to just touch up a few spots with the heat. But the problem with the powder is I'll get some spots on the film that are small creases, maybe 1-4 of them and they are very short.
Guest 515tinter
i dont think you can use "too much" soap. as for the creases, are you thinking of whats called peanuts? it sounds like thats what you're talking about when you say some come out, some dont. typically that is from over shrinking. so try to spread the heat around evenly instead of leaving the heat in one spot then the next. shouldn't need to wet check either, i dont think i've needed to wet check anything for a year or so. what anchoring method are you using?
    Tint My Ride
      EXPERIENCED TINT & PPF INSTALLER NEEDED IN NORTH DALLAS
    2. 5
      TintX Puremax and Koolmax
    4. 1
    6. 5
    7. 38
      Does anybody tint part time?
    8. 5
    9. 5
    10. 10
