Applying film on large BG hatchback
Guest CZtint
clean off properly, dont wet top of window (usually I dont wet top one or two heat lines) wet rest of window a lot, then I just remove whole liner and gets it onto glass, I apply corners of the film litte bit off the middle, and then move film to sides on glass taking advantage of excessive water with soap on it, so it doesnt touches anything, if film is falling down, just remove only half of liner and basically do little reverse roll, I think that is how you call appllying film with cutted liner on and do half and half, with little practise you will be able to apply them with ease, they are large but I find them not so hard.
