04 Accord Rear Deck
MONTANA TINT
I need to know if anyone can tell me how to take the back deck out of a 2004 accord. looks like the side pillar panels need to come out but they have air bags installed under them. help.
thanks
socalman
pull the light out.
first go into the trunk and twist the light for the bottom out of its socket.
go back inside and pull the light out while pushing down a little on the deck
so the light clears the panel
Sisqouc
To PULL THAT light
Eclipse
No you will not need a sawsall. Just push on the light shroud towards the rear of the car. Lift the light out and you are good.
Mdog
eclipse is right about the brakelight, take the bulb out from underneath FIRST then push on the brakelight housing towards the bottom and it will pop loose, you have to push hard and it will come out. as for the deck coming out I have NO IDEA, never had any reason to remove one yet
TD
The 2 door is a beotch
tintslut
did one today, that was tinted before.
Unscrew the speaker cover, it will save your hands.
Click here to view the article
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
