New camaro front side windows?
Guest jasonbuchanan
Guest jasonbuchanan
I am not having a problem tinting this vehicle its the drivers side window very bottom corner keeps lifting up. I have locked the windows in the up positon and have provided a lot of heat and drying time. They still come back within a couple days with the window peeling from the bottom. Please help as I have one in the garage now.
I have done lots of those and never had anyone come back. Do you pull the door panel back and pull the sweep out or try to tuck it? Maybe you are not getting it down far enough or it is pinching if you are tucking it...
double sweep isn't it? so if that then the bottom sweep could be picking the film.
Guest spfwindowtinting
Just cut your pattern a half inch longer. We don't pull door panels and just cut the pattern to sit bellow the seal. Leave them up for a bit and use a paper towel around a hard card and have no problems.
