Graphtec FC7000-130 (60") Plotter cutter For Sale
VWaholic
<p>Up for sale is my Graphtec FC7000-130 (60") Plotter cutter. Everthing is in great working order. I bought this plotter for my Residential and Comercial window tinting business. Turn out I don't use it as much as I thought I would. So, it's up for sale! Give my a call if you are interested. It does also have the Automatic Registration Mark Sensor for cutting printed stickers. $2800 <br />
Thank you<br />
Brent<br />
209-403-1998
</p>
<p><strong>Here's some info, pictures and a video of the plotter in action.</strong></p>
<p>Here is a link to a Graphtec PDF info sheet with all the specs. <br />
<a href="http://www.altaimagendigital.com.mx/Graphtec_FC7000.pdf" target="_new">http://www.altaimagendigital.com.mx/Graphtec_FC7000.pdf</a></p>
<p><strong>INFO:</strong><br />
<strong>Automatic Registration Mark Sensor (ARMS) and Dual Axis Correction</strong><br />
- ARMS automatically seeks for the fi rst corner mark to get the job started faster<br />
- 4 Point marks - Dual Axis Correction adjusts the cutline to compensate for minor print distortions<br />
- Use intermediate segment area marks to compensate for printer skewing on long prints</p>
<p><strong>Versatile, Flexible, Durable for High Production Output</strong><br />
- Cut, Plot, Pounce - Choose from several types of blades, pens or pouncing tool<br />
- Cut from 1 mil thin fi lm up to 50+ mil thick sandblast mask with ease<br />
- Order the two-pen model for maximum flexibilty and automated multi-function capability</p>
<p><strong>Industry Leading Cutting Speed and Precision with Tangential Control Mode</strong><br />
- The FC7000 is the fastest in its class with cutting speeds up to 58.5 inches per second<br />
- In Tangential Control Mode it outperforms mechanical tangential systems in both speed and output quality<br />
- Within milliseconds sensors detect the blade tip position to lift and rotate it for the next cut line<br />
- Precision digital servos and control architecture enables cutting of text on vinyl as small as 1/16th inch<br />
<br />
<strong>Higher Cutting Force - Intelligent Soft Landing Control</strong><br />
- Delivers a maximum cutting force of 600 grams to cut tough materials<br />
- Graphtec’s Soft Tool Landing feature ensures quick, precise control so <br />
the tool gently lands on the material surface - this improves speed,<br />
reduces wear, and extends tool life</p>
<p><strong>Cutting Master Plug-in included for complete output control</strong><br />
- Design, print and cut layouts from Adobe Illustrator or CorelDRAW<br />
- Set registration marks, orientation, position, scaling, paneling, tiling<br />
- Set and save media type, line style, cutting conditions by layer or color<br />
- Auto-weld paths, optimize cutting order, set multiple passes and more</p>
<p><strong>Wider Media path matches Wide Format Printer media</strong><br />
- Extra width for easy loading of wide vinyl and print media sizes<br />
- Maximum Media widths -75: 36” -100: 48” -130: 60” -160: 72”)<br />
- Configure for front or rear loading with multiple media brackets<br />
- Optional Media basket is recommended to keep media clean and off the<br />
floor, and it reduces static build-up when cutting vinyl and other films</p>
<p><strong>Video:</strong></p>
<p><iframe width="640" height="360" src="http://www.youtube.com/embed/3Ht5jBQRv2g?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
<br />
Here is a link to the video on YouTube if the video above doesn't work. <a href="
target="_new">
</a></p>
<p><strong>Pictures:</strong></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0361.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0360.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0363.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0358.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0357.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0351.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0349.JPG" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0350.JPG" alt="" width="800" height="600" /></p>
<p><img src="http://www.encorewindowtinting.com/plotter/IMG_0364.JPG" alt=" " width="800" height="600" /></p>
    2. 3
    3. 2
    4. 2
    5. 1
    6. 3
    7. 1
    8. 8
    9. 8
