Elantra GT
Guest Spoolme
Guest Spoolme
2013 Elantra
Nice little car, really easy to tint. The sweeps are really tight towards the back of the car on the fronts for some reason so for you panel poppers.
There is a screw located inside of the handle. Take a trim tool an put it in the notch of the square screw cover and it folds down to expose the screw. Phillips head. Look down inside of the door handles (where the pocket or void is), you will see what I mean. There is a little rubber mat at the bottom of each one of them, it's just laying in there. I used a trim tool to lift a corner and pull them out. This will expose another screw, also phillips. Take them out and pop the panel. There is a drain notch at the bottom of the panel that is perfect for a trim tool. Comes off easy and smooth, the sweep lifts right out.
    4. 4
    5. 4
    6. 4
    8. 4
    9. 4
