Experienced Window Film Professional Available
TintX Puremax and Koolmax
I’ve tried both pure max carbon and koolmax ceramic. So from what I’ve experienced the pure max is honestly very easy to work with and just feels right as the beginner I am. I’ve easily shrunken rear and front windshields as a beginner with the pure max so I know someonewith experience can easily work with it. However I’m not sure if just me but the koolmax ceramic has just been a headache thing to shrink on rear windows only. Heard the adhesive isn’t as good either especially by dot matrix’s which I encountered on a 2000 mustang. But yea I recommend the pure max line although I switched over to geoshield . -
4,171
4,171
Question about VLT variance
I just did a minor search on google and found this about the tinting laws of Illinois State. Windshield: Non-reflective tint is allowed on the top 6 inches of the windshield. Front Side windows: Must allow more than 35% of light in. Back Side windows: Must allow more than 35% of light in. Rear Window: Must allow more than 35% of light in. Please keep in mind that it is only for Sedans, if you have SUV then the law is different. -
UltraVision is the only decent quality with a lifetime warranty. However, $$$$ for a basic film that does not block heat on most of the options. If their dealer pricing was better, we would carry them.
