Door Edge
The only time I have had issues with door edges not sticking is when you stretch it going down. Make sure its long enough so that you aren't stretching much from top to bottom. The problem is the inside of the door has a weld line which lets air flow through it and will cause it to lift up if there is tension on the film.
You understand the problem, that's right, but,  I think the bubble is not enough to take off everything.
I'm thinking the problem is the adhesive.
I'm switching  brand for test.
Thanks to everyone who tried to help.
    2. 3
    3. 5
    6. 3
    7. 3
    8. 3
    9. 4
    10. 0
