Experienced Automotive Window Tinter Needed Knoxville TN
Flat Glass Installer NEEDED
Full time Flat Glass installer needed in Lady Lake FL. 3M film, residential and commercial. Mostly solar but some security. This shop has been under the same ownership and in the same location for 34 years. We are the oldest 3M dealer in the tri-county area. Chris Gehman Owner Underglass Auto Tech Inc 334 S. Highway 27/441 Lady Lake, FL 32159 352-753-5267 352-753-8886 fax chrisunderglass@comcast.net -
Now hiring experienced window tinter
Car Tunes Brandon is hiring to its growing team for full time position window tinter 8-6 Tues thru Saturday. Call Shannan or Jason with Car Tunes 813-661-4052 112 N. Parsons Ave Brandon,Fl 33510 -
Any XPEL Dealers?
Are there any XPEL dealers lurking that can answer a question? You can DM me if you prefer. -
13
Where can I order Window film online?
You can try Alibaba,and get some samples first.As I know,1 roll is about $100. Whats app:+86 18028875794; email: glassfilm@kashibang.com -
TintX Puremax and Koolmax
I’ve tried both pure max carbon and koolmax ceramic. So from what I’ve experienced the pure max is honestly very easy to work with and just feels right as the beginner I am. I’ve easily shrunken rear and front windshields as a beginner with the pure max so I know someonewith experience can easily work with it. However I’m not sure if just me but the koolmax ceramic has just been a headache thing to shrink on rear windows only. Heard the adhesive isn’t as good either especially by dot matrix’s which I encountered on a 2000 mustang. But yea I recommend the pure max line although I switched over to geoshield . -
4,171
4,171
Question about VLT variance
I just did a minor search on google and found this about the tinting laws of Illinois State. Windshield: Non-reflective tint is allowed on the top 6 inches of the windshield. Front Side windows: Must allow more than 35% of light in. Back Side windows: Must allow more than 35% of light in. Rear Window: Must allow more than 35% of light in. Please keep in mind that it is only for Sedans, if you have SUV then the law is different.
