Help with felt on side windows
I remove the bottom sweep on those. I only tape felt if it's really old and nasty. Flush the felts with slip with the window is down and get them wet where the glass still covers it. On your last pass cleaning use a platinum ez reach to squeegee the edges at the felt (gets the solution out but is thin and doesn't disturb the felt much). Then spray window and install, should come out clean. Target it well, and on those back doors it helps to also just pop the outer most tip corner clip and I usually use my Fusion handle to prop the panel out front the door a bit so there's more room
    4. 2
    5. 2
    6. 2
    8. 0
    9. 6
    10. 4
