DYNOcarbon from STEK-USA!!
Hello. I recently installed Johnson Daylight Natural DN 50 on a couple of windows. Solar energy rejection is 39%. The windows are double pane and the glass is supposed to be tempered 4mm + tempered 6mm. The roof overhang shades the top 1/3 - 1/2 of the windows. However, a few days after installation I noticed that one of the glass has cracked, presumably due to thermal stress. Should I remove the film from the rest of the windows? I installed the film on 24 of these windows (6 tiny houses) so now 1 out of 24 is broken. Or is it more likely that I just got unlucky and the glass had a defect? Is shading from the roof overhang such a big factor? The glass cracked. Is it really tempered? I thought tempered glass would shatter, but not crack. Thanks!
