Jackson and Madison, MS - Experienced Automotive Window Tint Installer Wanted
Question about VLT variance
Pulling information from some website.... what you posted is only part of the whole thing. -
4,171
4,171
I just did a minor search on google and found this about the tinting laws of Illinois State. Windshield: Non-reflective tint is allowed on the top 6 inches of the windshield. Front Side windows: Must allow more than 35% of light in. Back Side windows: Must allow more than 35% of light in. Rear Window: Must allow more than 35% of light in. Please keep in mind that it is only for Sedans, if you have SUV then the law is different. -
TintX Puremax and Koolmax
Did you install on the inside or outside? We always install the film on the outside (specially if it's double glass with air or gass between) If you install on inside it will be to much heat and crack is possible. good luck
