Full Time Tinter Position - High Volume Northwest Florida Business
12
How to shrink film on windshield?
Start by applying heat evenly across the film with a heat gun or hairdryer. Move the heat source back and forth over the film, keeping it about 6-8 inches away to prevent overheating. As the film heats up, use a squeegee to push out any air bubbles towards the edges. Be gentle near the edges to avoid creases or melting. If the film curls up on the edge, try using a heat gun to soften it and then press it flat with a squeegee. Practice patience and keep practicing to improve your technique. -
Did you get this taken care of? What were the results and are you pleased?
