Jeephelp202
Guest Jeephelp101
Guest Jeephelp101
Replaced window regulator and window switch on a Jeep 2004 Grand Cherokee window goes down but not up what's next
you have power to the motor when the window goes down, do you have it when it goes up with polarity switched? if you do the motor is bad or regulator is binding.  which switch did you replace? master switch on drivers door affects other doors, if this was not the one replaced it could have been the problem all along.  pull out the volt meter and work backwards.
this post is so old its probably solved...
Edited by brent
