Audi A3
Guest naughtydog
Guest naughtydog
Everything is cake apart from the front doors which are very tight. Be careful not to overshrink the back glass , I nearly did - that's me though!!
This is how I did the front doors - not saying this is the only way
  • Replies 20
Guest mattstronguk
how did you do the front doors? I had one in today and had to send the custy away and come back next week!
got film to slide right to edge of glass with my bone but after fininishing top edge and rolling up the film had creased at bottom of side seal.
please help I am stressed and now running low on pride!
Guest naughtydog
You can either remove the glass - that is how how I would do one now or I tuck the rubber in on the long edge with a white hard card. Install and give it plenty of heat.
There is a screw that can be removed which slackens off the seal but I found that way to be not much better.
Guest mattstronguk
hi just thought I`d give an update on this one, I took the door panels right off, (2 screws either side at top of panel, remove insert in grab handle held on with 1 screw then 2 more under this then just lift!)
When the panel is removed, slide film up to tight seal, and use a bone tool to lift that seal so the film slides under and will slide to edge of glass. Without removing panels you cant get the bone under the part of seal that is below the doorline!
hope this helps anyone out.
Guest goldtooth
cant be no worse than a jetta.
They are - tight as a fly's arse
:spit word..thanks for the heads up :nohit: ..have'nt done one yet :spit ..jetta's are cake to tint,I do at least 5 a week :spit
Guest naughtydog
This applies to the old shape one only.
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
    10. 2
