Can film help? 114F parked smoke glass... options?
4 hours ago, Tintguy1980 said:
The physics involved simply put = heat always seeks cold and therefore when cooling the interior, the absorbed heat in the glass migrates to the inside where you are using AC. There, Capt Obvious to the rescue.
Have you considered looking for a solid whiteout static-cling vinyl material that you could cut to fit the outside of the glass shape? This would certainly reflect the sun's energy away from the dark glass and assist in shaving a few degrees off the internal temp.. The static-cling would allow for easy removal when wanting to relocate. It does require the glass to be clean before applying. The beauty of static-cling is it's reusable over and over again.
Example: https://www.amazon.com/VELIMAX-Blackout-Blocking-Whiteout-Darkening/dp/B08CXP3RK4?th=1
Good idea thanks
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
