I hate . . .
Guest Andrew
I own a '89 CRX and the handle is stripped to where I'm unable to rool down window. How do I remove the inside door panel? I can't seem to get past the window handle.
Sounds like the plastic teeth are stripped on th handle itself...if memory recalls..you won't have to take off the panel..you need a C -clip remover (under $5 at autostore) That's what holds the handle on.pull the clip out ...handle will pop off , replace handle .
If you still need the panel off you 'll need a plug puller as well and a philips screwdriver
Go to walmart, get JB weld, go to car, pull on handle til you hear a "SNAP", apply JB weld and hold handle on til it stays on by itself, wait 24 hours, roll down window.
[*]249046
:hmmm
I can't help but laugh ...the solution of breaking it and glueing it back together sounds like a HACK solution. :hmmm
[*]249046
:aint
I can't help but laugh ...the solution of breaking it and glueing it back together sounds like a HACK solution. :dunno
[*]249055
...yep...I had to try and remove a window winder where some had used GRITFILL {no-more-nails
} not good......:hmmm:hmmm
[*]249046
:dunno
[*]249055
Ya, it's kinda ironic, to break something only to have the intentions of immediately fixing it. Works though.
:hmmm
    2. 3
    3. 2
    4. 2
    5. 1
    6. 3
    7. 1
    8. 8
    9. 8
