A serious trick for upholstery & stereo
Guest zolar
Guest zolar
I have a trade secret I am going to share with you kind folks.
My boss picked the vinyl & colors for this monster stereo I have been tricking out, part time, for about a year.
Anyway, the vinyl he picked was pearl white marine. This crap was so stiff you could hardly bend it around a corner.
My fabrication is really curvy 3D shapes in cloth & resin on MDF. So I had to come up with a way to bend this turd
grade marine vinyl, without seams, or sewing. After much trial & error I found something remarkable.
M.E.K methyl-ethel-keytone is a serious solvent, I have used for welding ABS together. I tried soaking the vinyl
in everything imaginable, with no luck, until I broke out the M.E.K.
If you roll the M.E.K. on with a paint roller, on the back side, it will separate the mesh backing from the vinyl & foam
underneath. just peel the backing right off.
Then the vinyl has the softest hand, and will stretch in every direction 200% or more!
It will tear very easily on a fingernail when stretching though, be carefull.
Anyway I am going to put up a few pix of the work in progress, to show you the vinyl looks stretched.
The only stock piece of interior in the truck is the dash, wich I buit on to. The dash is wrapped in one piece
of vinyl. There is not one stitch, or seam anywhere.
I hope you like the work, and the tip. It only took me 20 years of vinyl wrestling, to figure it out.
Z
And more to stretch around the rest of the truck in the next few weeks.
I will post more of this beast soon.
  • Replies 41
Guest zolar
I am going to post some more of my upholstery & custom audio, in the car audio & video forum.
If you would like to see more of my non-sewing work.
Z
Guest zolar
My humble thanks T4L.
I am glad you like it.
I am digging out the old pix right now. I might get 'em up tonight over in the 12V forum.
Z
Z
[*]284986
Guest zolar
Thanks Tintdesigns, I will take some step by step on the glass work,
Pretty simple stuff.
The sanding is the Biznitch.
I think I have the rough pix of the giant waveguide for the subs, and the B pillar panels, I will look.
Z
    2. 1
    3. 6
    4. 2
    5. 2
    6. 2
    7. 3
    8. 6
    9. 1
    10. 0
