Vinyl
Guest Wasp
Is there any great hearted one in here that can help me with vinyl?!?!?! I'm having a hard time shaping it to corners... Is there any secrets... All I get are wrinkled corners... And no work done... Thanks for the help! :hmmm:hmmm:hmmm
depending on how sharp  the corner is  some time you can roll
the vinyl back causing a little stretch and use the hard card to
rub only a 1/8" at a time
if you have pics post them might have better sugestion.
[*]294779
Thanks for the reply Tigerstripe.
Here is the car pic. That bumper coner is my problem...
Guest precisiontinter
if you are talking about pain protec. film you can use a steamer to soften the film and the adhesive stays wet so you can work with it. should lay right down
