It's probably worthwhile mentioning that I live in a climate similar to Dallas-Fort Worth Texas region (in particular around Denton/Sherman); Lawton, Oklahoma or Puebla de Zaragoza in Mexico -
- VLT%
- (and 5 more)
Follow up: Attached is the performance data for Johnson's Resi/Comm window films and if you look to the bottom you'll see DN50 has a solar absorption of 39%, which is well below the threshold of concern which is generally accepted as 50% absorption (with no shadow). With a straight line shading from the roof this does increase the risk, which is usually low for straight line shading compared to other types. I've also attached a pdf of Johnson's film-to-glass chart which is used to determine how safe a film is. The thicker the glass the higher the risk; you say 6mm tempered and 4mm is the cracked one (interior pane). The question now is what compass direction do these panels face? In the end, I'll just suggest you hook back up with the person that installed it and get his input. He had to have been comfortable suggesting that film. I still believe it's a one off cracked panel and the rest will be fine. It takes 2 seasonal cycles to know for sure. Truly your call as to whether or not to replace with something lighter such as DN60. Here's more helpful info that helps you question the glass type on the interior; is it plate or is it heat-strengthened (HS). I believe it is plate and not tempered or HS. Why? Plate glass with suffer thermal shock if the edge temperature is different than the center of the glass by 50 degrees F. Heat strengthened requires 100 degree F difference, and Tempered requires 200 degree F difference. Ryker chimed in and that stimulated further review. Good Luck with this. johnsonFilmToGlass_2021.pdf
