ZOLAR
The little goats are 9 months old and at the age of getting their heads stuck in the fence.? So we will talk about fencing for the little darlings today.? It seems no matter how many acres you make available some of the goats find something on the other side of the fence, a delicate morsel, that they just can not resist.? At this age they can put their heads through the field fence, but can't pull back out.? Of course, you won't have this problem if you dehorn your goats.? But we choose not to.? We have tried field fence, the 2"X 3" wielded wire and chicken mesh.? Probably in that order.? A mix of two fence types seem to be the best for us.? We started out with field fence and had to add barbed wire at the bottom to keep the goats from kneeling down and crawling under.? Then we added the chicken mesh to the lower 1/3 of the field fence so that they would not get their heads stuck.? With the new fencing we tried the 2" X 3" wielded wire.? It's amazing how quickly they can destroy the wielded wire.? And of course, the chicken mesh used alone works only with the bottle babies and then only when they are very young.? At present we use field fence with two strands of barbed wire along the bottom and an overlay of wielded wire.? We haven't had to go goat hunting for quite awhile using this method of confinement.
I think we need to get some of this for the TD NOOBS :cool
    2. 3
    4. 3
    6. 4
    8. 4
    9. 4
    10. 4
