Soap shrink technique
I'm a big fan of the soap shrink technique , however I was beginning to feel ill after a couple of months into it and couldn't figure out why(I keep a clean and sanitized house and tint shop...didn't even dawn on me that it was part of the technique).
Had some tests done and found out I was breathing in mold spores (couldn't figure out where ) till it dawned on me that they were on the black cloth I was using to spread the soap around on the back window.
It had gotten moldy , but I didn't see the mold because it was a dark cloth , I threw the cloth out ,started using a new one and was feeling better within a few days .
Bottom line:
.. good idea to at least wash/replace the cloth your using 1time a week at least ..all that heat and moisture on the same cloth is a breading ground for bacteria and mold .
If this idn't TOTW worthy of soap users, I hope at least this post saves someone from going through how I felt . :popcorn
I just use some shop towel for each job...then bin that piece
Naughty
[*]329487
That works ..I figured most of the people that uses this technique uses the same cloth because it lathers up better each time you use it :popcorn
    2. 3
    4. 3
    6. 4
    8. 4
    9. 4
    10. 4
