NooB question of the day. (part 2)
Guest MidcoastMW
black trash bags work great if it is sunny out
even if it is only 65-70 Deg.
just keep it wet underneath
might even use hot water in the slip/simple green solution
If it helps rental companies have wallpaper steamers for rent
that would be sooo much easier
the glass and seals could look spotless in about an hour
Guest tint rookie
[*]332040
I priced renting one once for a big removal job, just to have a 2nd one working at the same time. dolla fo dolla, spent the extra 30 bux and bought a second one.
theres a million and uno uses for em, and its nice to have a back up.
I like my $50 special so much that I am considiring
one of those commercial steamers you can stand on
they go for about 2 bills but are much more rugged
and have bigger tanks, and longer hoses
Guest tint rookie
long hose...the key for sure.
I got one as a gift, sh!t you not 24" hose, I was gonna recycle it as a gift, ended up using it when my real steamer took a dump.
dug it out of the box, got in the car, bought a new one.
I went to local lambda dealer and had em retro fit a longer hose on my work horse. DO NOT USE AIR HOSE, pressure plus heat and rubber not rated for hight temps esplodes mayn. (hence needing a new hose in the first place).
with the longer hose they do tend to get a lil more spit action mixed with the steam but still work great.
