NooB question of tha day (part 3)
Guest MidcoastMW
Guest MidcoastMW
When you guys do your final squeege on the back glass.......do you go against the defrosters (perpendicular to the ground) or with the defrosters?? (side to side, parallel to the ground)
Whats your method????
Guest MidcoastMW
:coffee tank you mastah
thanks guys. Anyone care to get into more detail? Like, side to side...ok...but workin top to bottom, middle out??, etc....or does it even matter?
and push the squeegee
never pull it
I lay it down in a + shape the center up & down first, then the side to side in the center
then work out the corners and bottom edge then the top
after I get it all squeegee'd out....... I go over it again....HARD
try to get out most all the slip
.....the longer it stays on the adhesive
the worse it is on adhesives and uv absorbers :coffee
and will shorten the film's life :coffee
