'61 Chevy Impala Bubbletop
Guest CloudWalker
hey cloud, you should try the baby powder shrink on that one....it's the way I'd do it, and it looks fairly straightforward if you've powder shrunk before :lol take your time and you'll get it. :lol
  • Replies 25
Guest tintgod
I just noticed from your pic that it looks like laminated glass, id be carefull not to get it too hot.
:lol ..I would be really carefull ..go much heat..and it will crack... :hmmm:lol
I've got one coming next week. The shrink looks easy, im guessing the rubber surround will be nasty. Is everyone cutting short & using vinyl tape on exterior or leaving daylight or hiding the edge ? Tips are appreciated, I've never had the pleasure of doing one. :lol
Sides are cake the rear top corners are a MF but can be done. took me more than one try. If you can pull the rear glass its ten times easier to fit and it looks sooo much cleaner. I tried once in the car and then had the glass pulled.
Guest Sunlimited
Hardest back window I've ever done...If the glass is out of the vehicle though it shouldn't be bad.It was difficult because it's so bowed you can't really cut it right on the exterior. I had to shrink it outside, cut it, shrink it inside as best as possible, then for safe measures I made as many fingers as possible and shrunk again outside...PITA
    2. 6
    3. 3
    6. 3
    7. 6
    8. 3
    9. 6
    10. 4
