anyone still do this
Guest keepitcool
Guest vclimber
im interested in the wood turning tool
[*]360071
:lol not good at postin pics, but it basically 5-6" long wooden handle with a 1"long V shaped steel bit on the end that has been sharpened the V would only 2-3mm each V, dont even know the proper term, used to carve wood sculptures.. :thumb
Oz........... :inot
[*]360072
You mean a chisel? No way, you've really tried that on glass???
[*]360079
:) I think a chisel is just the flat type, this is a V shape??
not sure if the Ozy term is different??? :thumb
so you are hard up against the wood and guiding on top of the glass, pressure is on the wood. :inot
:inot Oz..........
[*]360081
Even if you could pull that off. I could see it taking a long time to finish a window. Then there is the contamination issue... I don't know? I'd try and sell em some 60% Spectrally Select Film and tell him it will perform as well as the dark stuff but you'll never know it is on the window... End of light gap issue.
  • Replies 20
Guest TintsOvOz
[*]360071
:lol not good at postin pics, but it basically 5-6" long wooden handle with a 1"long V shaped steel bit on the end that has been sharpened the V would only 2-3mm each V, dont even know the proper term, used to carve wood sculptures.. :lol
Oz........... :inot
[*]360072
[*]360079
:? I think a chisel is just the flat type, this is a V shape??
so you are hard up against the wood and guiding on top of the glass, pressure is on the wood. :)
:inot Oz..........
[*]360081
[*]360089
I quickly just run it a round the edges prior to starting the fit, for the purpose of just removing the loose bits I.e. paint silicone etc just before the normal scrap, scourer, flush, squeegee process, gets rid ov the daggy bits.
yes it is always nice to do the lighter films but on the odd ocassion they want or need glare or fade etc
not trying to change anyones stlye just happened to answer the first post and I dont use this process if the windows are putty fit :inot now thats a different story, I understand the doubt but it can save some time on fingers and dirt issues especially on the 6"x10" paneled doors at the end of the job I find the film to be sitting nicely :thumb:lol
I did a couple of years of glazing before I started tinting which gave me some knowledge on glass & frames etc
Oz........... :?
won't work as well as the dark stuff if he's trying to eliminate glare on his computer screen or tv. :poke
Guest vclimber
[*]360262
The dark stuff won't eliminate the glare as well as most couch potatos would like. Time for a blind if that is the case.
How dark is the film that you want to put up?
If it is 50% or lighter, the gap should not be a big deal...
Old guy selling Vista for $2.xx/ft will probably keel over and die because he aint gonna make a living selling it for that much. we all know how much it costs.  :spit
[*]360073
:spit:bat true that, but hell, I woudn mind making 3$ per sq ft :DD
Running the film to the edge isn't anything to do with thermal fracture and temp difference... what a bunch of baloney... The film/glass inside the frame is still shaded therefore still cooler than the exposed glass... :spit:spit
Guest vclimber
Running the film to the edge isn't anything to do with thermal fracture and temp difference... what a bunch of baloney... The film/glass inside the frame is still shaded therefore still cooler than the exposed glass... :spit  :bat
[*]360344
Call it creative marketing. He just creates whatever story he needs to market his product and service. :spit
[*]360348
Hmmm... reminds me of another discussion all together.... :bat
Isn't it so... they're everywhere and in every industry... :spit
    Tint My Ride
      Window tint full time position available
    2. 1
      Portland, OR - Seeking an Experienced PPF Installer
    4. 1
    6. 0
    7. 3
    8. 3
    9. 0
