2001 Honda CR-V
Guest gonetintsup
Guest gonetintsup
I've just finished doing a CR-V and the back window was a sod to do. Might have to do it again as there are quite a few iar bubbles around the heating elements etc...any hints on how to get around this?
Guest imfear44
that back window su**s, a lot of guys just tint to the matrix lines that run vertical on the sides then use tape but it takes time if you tint to edges and bhind light
Guest gonetintsup
[*]393115
Excellent tip, it'll save so much time. It took me 4hrs from start to finish taking all the hardware off and filming round the holes!
I always remove the glass on the CR-V's back window. Only a few bolts and screws and saves so much time rather than trying to cut around all the wires and bolts.
The new CR-V's are the same but not as bad as the earlier ones. I cringe everytime I get one in but they are not too bad really.
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
