AUDI Q7
Guest drejc
The easiest of all the Audis.
Pull off the door handle cover. It just pops off. 2 screws behind it. This releases the pressure on the door panel so you can pull the top of the door trim away from the door. The rubber gasket comes out easily.
Apart from that, its a big car with a lot of glass. A BIG freakin car.
Your the man, These monsters are surfacing in the burbs as I write,Look forward to many more. :gasp
  • Replies 24
Guest naughtydog
I did'nt pull the panel - just popped it back.
I'm always a bit scared of scratcing the film when putting the window back in and I feel you get less dust in the job with the glass in the car. ?
I like the look of your workspace - can you get me a close up of your film rack - looks awesome.
Naughty
Just had one in today.
Thought Id take a couple of pics of the spoiler off for anyone who needs help. 5 minute job max, just pop off the plastic trims and there are 4 x 10mm bolts to un-do. Then release 2 electrical connectors and there you go.
It does make the shrinking easier for sure in my opinion :-)
