1996 Corvette
Guest B.C.
  • Replies 34
Guest haroldshouseoftint
ok that is the onyz series, were you wet shrinking it or dry shrinking it? that doesn't matter wet shrink it and you should not have any problem with it, I assume it is a 36" roll, leave the top and bottom hang over enough to do a pull method with it that is not that hard of a window especially if you are wet shrinking it :thumb
Guest VaTinterPMan
Yeah what the true tintman said. use a 40 inch roll if you have it. just to be safe. why wet tho???? wouldnt dry be just as good. ? even with a pull techn. :thumb
