1998 accord back window
Guest mrflip09
  • Replies 23
Guest VaTinterPMan
Here's a lil tip for the dots its not going to loook good if you dont do anything to it so, and it first. but take tape and put it 4inch deep for u I do 2in just incase u slipp. put the tape along the buttom of the past dot. Then sand and clean very welll. And install tint if u get it shrunk without creases. and if u dont like the out come of the dots after sanding pull down to the bottom of the dots and put glue on it will be fine. ELmers blue glue dries clear. And use the mdog shizz for shrinkin..,..
Use 0000 or 000 steelwool for sanding the dots and you won't have to worry about scratching the glass. Make sure after you give it a good scrubbing that you wipe them until there is no more black :lol2 on your towel. After I install the film I will pull the film off the dots and spray Dirt Off/ x-100 on the film and then lay it back down. Then I use a 3M black card with a paper towel and slowly with alot of pressure squeegee the water out of the top.
If this doesn't work glue it :lol2
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
