Laminated glass
Guest expertint
Guest vclimber
37-40% SA is not what is going to kill you. It's shadowing, altitude, and or big temp swings... especially the shadowing. Just a little bit can be a big mess. :eyebrows
  • Replies 45
Silver 20 would be a better choice IMO (then again, that's always my opinion).
me too,
NV series film are very reflective in my opinion once installed, might as well find a different reflective film that the absobtion rates are not that high :eyebrows
Guest dave1290
If you do proceed... Make sure you have the customer sign some type of waiver making the risks clear and that they are not your responsibilty. :eyebrows
Cover your butt! :nope
Guest darkdan
37-40% SA is not what is going to kill you. It's shadowing, altitude, and or big temp swings... especially the shadowing. Just a little bit can be a big mess. :krazy
Well it's the SA that makes shadowing, altitude, and big temp swings a problem.
If it absorbs zero than all those things wouldn't effect it.
NV is supposed to have low interior reflection, which is accomplishes that decently well.
Guest vclimber
It's the difference in glass surface temperatures not simply the SA. Films that are similar to NV-15 in SA are ok on clear IG Laminated IF there is no shadowing, altitude, or big temp swings. Any added external factors and it is not recommended.
Guest vclimber
Yeah, and if it absorbed zero there would be no glass surface tempature differences when partially shadowed.
Clear glass doesn't even absorb 0%, clear film is the same. There is always a temperature difference, even on the bite inside the frame there is a difference in temperature. Now you are talking a difference in temp on two pieces of glass that are essentially "glued together". The heat distribution gets all screwed-up. That make things even worse when a shadow is cast on the glass or you are at altitude. 1-2 points for altitude, an additional 1-3 for shadowing.
Guest darkdan
Of course there's always a difference in temperature.
But you're missing my point.
Less SA means LESS difference which means slightly safer.
ZERO was just an example to try to get my point across.
Guest vclimber
I understand your point. But if you research it, things are much more complex than just SA. :krazy
    2. 1
    4. 1
    6. 1
    7. 8
    8. 8
    9. 3
