>>>>>>>>> Global and a tinter with a workshop. Global is another solid contender in the industry and I am sure they have Eastman barked up a tree. I can't say how I know this is possible, but Global has been long over-looked by most mannies. They silently crept into the US market for years before you hear tinters praising their products. I have installed Global to my home and have 3M on one car and LLumar on the second. -
- VLT%
- (and 5 more)
