07 g35 Sedan
Underground
Guest BLACKOUT SoKal
the reardeck doesnt come out easy, I didnt really try, but with a bulldozer you can press down on the reardeck and it'll give you enough room to get the film smooth behind the thirdbrakelight. for the wing windows just run the blade along the gasket, I dont recommend trying to tuck the film in its very tight and the rollups are basic :thumb
Guest shaver
the reardeck doesnt come out easy, I didnt really try, but with a bulldozer you can press down on the reardeck and it'll give you enough room to get the film smooth behind the thirdbrakelight. for the wing windows just run the blade along the gasket, I dont recommend trying to tuck the film in its very tight and the rollups are basic :spit
I went ahead and tucked the rear corners, with enough solution the film slit right in. Alos, It wasn't a problem for me because I'm not a big guy...but that rear deck could be a pita! Bulldozer like posted above me here is the key for completing the job (without taking out panels).
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
