i need a
if you have a floor or table you can pull it out on then lay the box top in front of the roll and box. Then put the blade through the film at the desired width and pull out how much you need to pull.....just watch the roll "wobble" as it can vary the cut a small bit....
if you need a precise cut then you may not get that exact...just depends on how tight the edges of the roll are.
thanks but im wanting to fit it on my fiml hanfler which is a 60 in model....I need 64 inch pieces...and each piece is 115 in long....I have cut film how you suggest and will have to if I cant figure a way to just cut the whole roll at once....thanks
