Corvette Tips
Guest socalkid
Guest socalkid
thanks for the tips and support guys. I'm pretty excited about doing the vette. I just want to have a good feeling about the install after it's all said and done. I'm sure y'all know what that feels like! :eyebrows
On the bumper, I've had best results using a modified coast to coast only starting at the turnsignals (turn2turn). Just need to tack around the inside half of them at first but make sure your alightment spot on those things. Next I pull down from the middle until the emblem is lined up then tack the bottom center of the bumper. Then tack around the bottom of the emblem and stretch up and tack the corners by the lights. Next down to the bottom part by the fog lights. Once those are tacked, squeegee out the middle of the bumper taking the slip out between those tack points. Tacking corners like that leaves the spaces between them easy exits and you don't distort the film hammering out a bubble through a "tack zone".
I used to start out around the emblem and work one side them the other but that always left stretch/lift marks around the center (and most noticable ) part of the bumper.
    3. 6
    4. 4
    6. 4
    8. 6
    9. 4
    10. 6
