95 LHS A/C
Guest barouk
Guest mrpain
ck ......fuse...............dash switch.......................belt.............................plug on the a/c unit......................
........????????????????freon????????????????????
sometimes if the system does not have enough freon it will not work
Guest tinttec
Make sure the a/c is full of freon. Those LH series cars were known for pressure switch failures. The switches are normally located in the manifold hose assembly. They can be found near the compressor can only be accessed with the car on lift. If the switches check out okay then thier is a good chance the PCM is bad in the car. Failures of the PCM are very common.
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
