2009 TSX
Guest tint51
no need to remove the rear deck, push down on the light and use the bulldozer, u have enough room
Thanks..
I must not be getting enough push behind it as the bottom wants to come off..
Thanks..
Found out you need the brake light cut out to have it lay down..
Guest tintmanlibby
Thanks..
order a red devil there awsome
Thanks..
Will check into that.. Thanks for the info...
Guest Solar Impressions
It's really not that hard to pull the deck, and with the upcoming hot days ahead no need for wasting time trying to get behind it before it dries.
Guest tint51
Have been using the bulldozer to lay behind B/light.. works great!.
